Main Forum » Notams » Bluesky V2 General Information
Author Topic: Bluesky V2 General Information (Read 197 times)
Posted at: 18-09-2017 18:42:52
Please let us know in the forum if you find an issue.
Scoring system basics.
You will start off with basic points for each flight you fly, points will be deducted for operating outside the parameters set which reflect real world operations, example flap and gear extension speeds, over speeds and stalls, your landing rate and an ontime bonus is also incorporated in to the system.
Bluesky will look at your take off and landing runway used with your current simulated weather conditions to ensure you are using the correct runway for the weather. You are allowed at pilots discretion to take off or land with a tailwind component up to a maximum of 10kts, anything above 10kts will incur a penalty.
Updated Landing Rates for all aircraft.
Landing rates 0 to -78 = - 100 points (Dangerous floating landing)
Landing rates -79 to -150 = +100 points (Very good landing)
Landing rates -151 to -649 is +50 points. (Acceptable Landing)
Landing greater than -650 is -100 points (Aircraft out of service for checks, heavy rate)
Landing greater than -1000fpm will result in PIREP rejection.
