Main Forum » Crew Room » Landing Rate
Author Topic: Landing Rate (Read 291 times)
Posted at: 07-02-2019 09:45:12
Not a Big problem whatsoever but any idea why my landing rate of 89 ft/min is not showing up in Stats ..
Was really proud of myself too as it best I have ever done in the bus HaHa....
Also flight on 4th Feb of 93ft/min not showing either.....
Last updated by on 07-02-2019 09:59:12.
No Avatar
Posted at: 07-02-2019 11:05:05
When did you do it David? I will have to check what the cut off was as I can't remember now.
Posted at: 07-02-2019 11:23:55
Hi Mark,
Err the 93ft/min was on 4th feb  and the 89ft/min was yesterday .As I say not a major problem but just wondered why they hadn't registered in the Stats..
Cheers
Dave
Posted at: 11-02-2019 16:36:57
Slightly off topic but it is about landing rates.  I find that if I try to 'grease' a landing in the Airbus that it tends to eat up runway and speed doesn't bleed off too quickly.  A firm landing rate, say 200-300fpm seems to work better for me.  This is with the FSL Bus though - it may be different with the Aerosoft Bus.
Posted at: 11-02-2019 21:58:56
Hi Rob
It was Aerosoft Bus but yeh normally around 200 250.But on these occasions i managed to get in the zone But as I said for some reason they didn;t show up in the stats even though they were recorded correctly in my pireps....Hey Ho !!!!!
Andy S
Senior Training Captain
Posted at: 21-03-2019 07:31:05
Hi Matt, Mark will explain better than me,however, a very low landing rate is classed as floating the aircraft ,therefore its classed as a bad landing.
Andy
P3D V5.4
FSLabs A319/320/321
FSLabs A320SL/321SL
MSFS A320NEO FBW
FENIX A319/A320/A321
No Avatar
Posted at: 23-03-2019 14:18:27
We have a minimum landing rate set at I believe -75fpm, I can t remember without looking at the code but anything softer than that is classed as greasing it, so unsafe.
Posted at: 07-10-2021 20:25:46
Last landing rates not registered (I don´t know why)
smiley
;">-53 fpm
-20 fpm
-36 fpm
Fran
Andy S
Posted at: 07-10-2021 21:12:33
Fran
smiley
-20 fpm
-36 fpm
Fran
Which flight?
All the flights you have flown it as registered.
P3D V5.4
FSLabs A319/320/321
FSLabs A320SL/321SL
MSFS A320NEO FBW
Posted at: 08-10-2021 12:13:08
Yeah, you are right. I mean they are not registered in the Top Pilots page. smiley
Thanks!
Fran
Andy S
Posted at: 08-10-2021 12:22:42
Yep, that's correct, because they are considered too low
Mark
We have a minimum landing rate set at i believe -75fpm, i can t remember without looking at the code but anything softer than that is classed as greasing it so unsafe.
P3D V5.4
FSLabs A319/320/321
FSLabs A320SL/321SL
MSFS A320NEO FBW
