For a bit of fun.
I am setting to following challenge to all JetVa pilots that fancy something different to do. There is no prize apart from the pride of being accurate and on time.
The challenge is to land at London Gatwick on Sunday the 20th September 2020 with a landing time of exactly 20:00Z that is 21:00 local time.
It is the Landing time that will be used from Blue Sky
You may fly in from anywhere
You may fly on any network or offline. ( I will be on VATSIM - please keep out of my way ha ha ha...)
You must be in an easyjet livery airliner
You must file via Blue Sky so that it can be verified
Weather of your prefered system should be used - but realistic online weather will add to the fun. Still air 'all the way' defeats the object a little
You must follow online ATC, if your flying it online (I will be) Though asking for 'directs' is a given if running late
You must of course land without crashing ![]()
Naturally this will use your PC clock, but they are normally synced to the net.
Time to have a bit of fun ![]()
