I have no issues using MSFS, however, I always seem to run into problem with X-Plane. I am in the ToLiss and just started at the gate but when I try and start the flight, it says "Engines Running" I can tell you, they are not ![]()
| Main | Search | Team |
| Author | Topic: Engines Running? (Read 90 times) | |
Total Posts: 4 |
Posted at: 04-01-2021 12:46:42
I have no issues using MSFS, however, I always seem to run into problem with X-Plane. I am in the ToLiss and just started at the gate but when I try and start the flight, it says "Engines Running" I can tell you, they are not |
Andy S Moderator Senior Training Captain Total Posts: 105 |
Posted at: 04-01-2021 15:41:18
Hi, Just ensure you have the latest xpuipc installed. Andy
Total Posts: 4 |
Posted at: 05-01-2021 05:44:14
Thanks for the response! It seems mine is dated from 2019. The latest I found is 2.0.5.25. Is there anywhere to get the most recent? Most sites aren't updated or have old files. I tried the above file and had the same result. Last updated by on 05-01-2021 06:13:22 (Updated). |
Mark Grant Administrator Training Captain Total Posts: 192 |
Posted at: 05-01-2021 12:31:44
It might be worth a try to see if the older version on this site will work, to be honest, I have no ideas but it may be worth a try.
The download is located https://www.jetva.co.uk/index.php/downloads/dl/37 Many Thanks, Mark.
Gunter Riedel Captain Total Posts: 2 |
Posted at: 14-06-2021 16:24:52
I have exact the same problem with the Flight-Factor A320 :-( |
Posted at: 27-10-2022 16:57:00
Recently I have updated my xpuipc. Now it works!! |
