Main Forum » Crew Room » TCA Sidestick modification
Author Topic: TCA Sidestick modification (Read 82 times)
Posted at: 04-10-2022 19:26:42
For those using the TM TCA Sidestick.  If you find that the 'twist' axis on the sidestick is 'twitchy' and doesn't return smoothly and quickly to the neutral postion then it is worth carrying out this modification https://youtu.be/adAyDgWEqiY  Whether you use the axis as a tiller or a rudder it will make a considerable difference to your aircraft control.
Posted at: 26-10-2022 12:22:28
Thanks Rob, I have this problem and I use this as a tiller. I will try the mod.
MSFS FBW A32NX
Posted at: 26-10-2022 13:17:50
It worked, thank you Rob for sharing. i thought that my unit was faulty and thus the strange behavior but this resolved it!.  This is great. For everyone trying this, just be careful with the cables when putting it together as a I almost cut through mine.
MSFS FBW A32NX
Posted at: 29-10-2022 14:28:58
Hi Miguel
I'm pleased it worked for you.  I must admit that my heart missed a couple of beats when everything fell out when I parted the joystick!  smiley  Luckily it all went back together OK and is vastly improved.  But as Miguel says, be careful not to trap any wires as you re-join the two halves of the joystick.
Posted at: 04-11-2022 19:37:27
I have this problem every now and then but never thought of pulling some slack through until now, just done it.
Watch me @ https://www.twitch.tv/matty260191 (LIVE) or https://www.youtube.com/channel/UCH4wiMH3-ChVrnd_tz6_myw
Connor Sullivan
Captain
Posted at: 21-10-2023 17:52:21
Hi,
I was wondering if someone could please explain the steps involved for this as the video link does not work for me unfortunately.
Cheers
Connor
Case: Thermaltake Level 20 Tempered Glass (ARGBCPU: Intel Core i7 9700K 3.6GHz Octa Core CPU Cooler: Masterliquid ML240L RGB  Graphics Card: NVIDIA GeForce RTX 2060 SUPER Primary Screen: Acer KG271 27in Motherboard: Z390 AORUS PRO  RAM: 32GB  Storage: 3TB  PSU: EVGA GS 950W GOLD  OS: Windows 10  Keyboard: Avenger Keyboard & Mouse Accessories: TCA Airbus Quadrant & Sidestick
Posted at: 21-10-2023 20:04:01
Hi Connor
Try this video https://youtu.be/N-W-9W1CStk?si=jBSw4T3Me4uv4l8k It shows the same procedure. Rob
Connor Sullivan
Captain
Posted at: 24-10-2023 09:34:47
Thanks very much Rob! It seems to have worked nicely smiley
Posted at: 24-10-2023 09:42:12
Pleased to hear that Connor.  Thanks for letting me know.  Rob
