Main Forum » Flight Operations » UK Schedules info
Author Topic: UK Schedules info (Read 82 times)
Posted at: 16-03-2023 14:49:33
I've completed the first sort of the data for our UK schedules by separating it out airport by airport.  The next step is to sort each airport's data into a format acceptable by our own database.  This will take a while. smiley  Below are the weekly Arrivals and Departures for each airport.  As long as you live you'll never need to fly the same flight twice!  This is before I start on the EJU schedules!  All credit to Andy Smith for doing this job in the past.  It's huge!
EGAA536
EGBB96
EGCC462
EGGD542
EGGP180
EGGW648
EGJJ80
EGKK1548
EGNS60
EGNT42
EGPD36
EGPE60
EGPF236
EGPH384
EGSS106
TOTAL5016
Posted at: 23-03-2023 13:05:27
UPDATE
Making good progress.  All UK schedules now complete except EGKK which is 50% done.  Having a fly today to check out MSFS SU12 to look at something other than spreadsheets! smiley
I should be able to get them to Mark for uploading by the weekend.
Last updated by Rob on 23-03-2023 13:07:09 (Extra info).
Barry Ford
Senior Training Captain
Posted at: 24-04-2026 04:42:44
I'm posting this here instead of starting another topic as its the nearest thing to my query,
For the last couple of days when Ive gone to set a flight up with ACARS & choosing the flight from my booked list, It keeps returning schedule not found ? Its not every flight but its frustrating when you arrive & then do the follow on flight to find "Scheduled not found" from my booked flight list in ACARS, albeit Ive booked via assigned flights in the schedules menu.
Cheers
Barry
Andy S
Posted at: 24-04-2026 07:48:02
Have you tried clicking on Refresh in Bluesky underneath DATA/
Also click on "current bids" to see if it's there then highlight it and finally clickn"Flt Bid " at the bottom.
Barry Ford
Posted at: 24-04-2026 08:14:47
Good Morning Andy,
Yes Ive tried all of what you have said to no avail, Yesterday in the end I was deleting flight then booking another one that it found,.Its doing it again now I can fly EGCC to LKPR but "schedule not found" for return flight to EGGD
Andy S
Posted at: 24-04-2026 08:46:24
Is it in the current bids on Bluesky?
I have just booked both and they are there,but i obviously cannot fly them as i'm already in flight
Andy S
Posted at: 24-04-2026 08:57:45
Aha
It's because several different routes are using the Flight number.
I have just changed it, so do a refresh and use EZY473K
Barry Ford
Posted at: 24-04-2026 11:03:56
Andy
Yep that works,Thankyou, however EZY43 LIPX to EGGD has the same issues "schedule not found" sorry frown In any case Ive got the day/night off so going up the pub for a few pints, I shall continue later,
Again thankyou
Andy S
Posted at: 24-04-2026 12:26:07
Done that one too.
There are several that need looking at.
Posted at: 24-04-2026 14:59:48
We have had a massive overlap of imports from summer to winter for a couple of years now, from different sources, all combined onto one database. The cleanest solution would probably be to remove older schedules, but we needed a way to capture all flights and insert them into the system, which is why the constraint was removed.
We have also now started adding additional import data so that we can check what to remove going forward.
Barry Ford
Posted at: 25-04-2026 07:39:08
@ Andy ,thanks for sorting it out, @ Mark all good I were'nt complaing I wondered why this was happening ? I appreiceate all the hard work it involves ruuning this VA.smiley
Posted at: 25-04-2026 07:45:31
No its fine mate, we need to get this right and it only improves when problems are flagged up. I can fix them then.
