Main Forum » BlueSky v2 Support » FBW AIrbus A320 Landing Rate
Author Topic: FBW AIrbus A320 Landing Rate (Read 19 times)
David Stirling
Captain
Posted at: 01-07-2024 13:32:15
Hi,
Thought I would try out the FBW instead of the Fenix .
However is there a certain aircraft to load on Bluesky as I am getting a high landing rate message
even though it was below normal landing rate...
Thanks in Advance
13:14z] Score Triggered - High Landing Rate | Threshold: -650 | Actual: 24.61 | Value: -100 | Delay: 0
[13:14z] Current Score: 50
[13:14z] View Mode: Virtual Cockpit
[13:14z] Reverse Thrust Started: 114
Last updated by David on 01-07-2024 13:32:59 (spelling).
Posted at: 01-07-2024 17:22:14
HI David,
I did see your report, it looks like a positive landing rate, this usually happens when there is a data error received from the sim, looking at your log it shows the following,
[13:14z] VS: 24 fpm
Clearly this is not correct as its a positive number which is why you received a -100 points penalty.
The aircraft profiles in bluesky shouldnt matter which one you select, it most probably a coding error with fbw.
It would be interesting to see if anyone else is reporting positive landing rates in the FBW.
One thing to check is ensure you have the latest fsuipc installed as this has been known to make a difference expecially if developers change their code.
David Stirling
Captain
Posted at: 01-07-2024 18:30:53
Thanks Mark
I do have the latest Fsuipc installed .
I will try anoher flight see if it still throws  up the error..
Thankyou..
Dave
