Main Forum » X-Plane » Blue Sky V2 not compatible with XP12 (Windows 10)
Author Topic: Blue Sky V2 not compatible with XP12 (Windows 10) (Read 25 times)
Moritz Brandstätter
First Officer
Posted at: 28-07-2024 19:02:28
Im currently flying from Gatwick to Faro as EZY8541. Problem is: The current version of XPUIPC is only compatible with XP9 to 11 and when I use it with XP12 my sim just crashes. Does anybody have a solution for this? And also, does filing a manual PIREP count as a completed flight (without using BlueSky)?
Last updated by Moritz on 28-07-2024 19:05:23.
Posted at: 28-07-2024 20:13:02
Hi, yes flights still count if filed manually.
I did see a post that xpuipc for X-Plane 12 has been released, http://www.xpuipc.com/
Hope this helps.
Kind regards,
Moritz Brandstätter
First Officer
Posted at: 28-07-2024 23:42:07
Thank you very much Mark! Instillation was a bit tricky but I figured it out eventually. Also quick (newbie) question: For each scheduled flight there are departure times and arrival times. Do I need to depart at excactly that time or can I fly that route whenever I want?
Sincerely,
Mo
Posted at: 29-07-2024 08:08:45
Moritz
Sincerely,
Mo
Hi Mo, no, you can fly any schedule at any time, if you want to change the time if flying online or just for your sanity, then you can update this via the simbrief generation page and simbrief will update the flight plan to the time you input.
Thanks,
Moritz Brandstätter
First Officer
Posted at: 29-07-2024 11:29:22
Mark
Moritz
Sincerely,
Mo
Thanks,
yes
