Hi,
What is the callsign for ATC when the flight number starts with U2...?
Thanks,
Harel
Main | Search | Team |
Author | Topic: Callsign U2 (Read 53 times) | |
Harel L Captain ![]() Total Posts: 12 |
Posted at: 07-12-2024 06:51:41
Hi, What is the callsign for ATC when the flight number starts with U2...? Thanks, Harel |
Andy S Senior Training Captain ![]() Total Posts: 57 |
Posted at: 07-12-2024 09:22:42
Hi, All easyJet flights start with U2 in Flight Planning,you can see that on Flightradar24 however, Flights using EZY are Easyjet,flights using EJU are Alpine and flights using EZS are Top Swiss. These are ICAO codes Just to confuse even more Flight numbers also use Easyjet U2,Alpine EC and Top Swiss DS . These are IATA codes So Aircraft registrations starting with G easyjet,OE Alpine and HB Top Swiss,(normally) Hope its not too confusing P3D V5.4 FSLabs A320SL/321SL FENIX A319/A320/A321 |
Posted at: 07-12-2024 10:12:39
Thanks for replying. I am aware that EZY - callsign is EASY; EJU - callsign is ALPINE etc. Not sure what is the callsign for U2. Is it also EASY? |
Posted at: 07-12-2024 10:25:39
The best way to check is.... Go to Flightradar24. Type in the U2xxxx then you can see the callsign.... e.g. U21231 =EZS18PB,therefore Top Swiss 1 8 Papa Bravo U24324 =EJU823F, therefore Alpine 8 2 3 Foxtrot U2310 =EZY573C,therefore Easy 5 7 3 Charlie
In real world flightplanning all Easyjet Group use U2 Last updated by Andy on 09-12-2024 09:35:52. P3D V5.4 FSLabs A320SL/321SL FENIX A319/A320/A321 |
Posted at: 07-12-2024 10:54:40
Ah Ok, now I got it Thanks! |
